ok, if all i want to do is control my timing and a/f, what do i NOT need to add
basically asking what i don't need to get on this list underneath
E-MANAGE (basic unit) piggy-back engine management unit 15500500 $379.00
E-MANAGE INJECTOR HARNESS for main and sub. inj. control 15900901 $38.50
E-MANAGE IGNITION HARNESS for ignition timing control 15900902 $41.80
3.0kg/cm2 PRESS SENSOR use w/ factory A/F meter or MAP sensor 16401301 $120.00
PRESS SENSOR HARNESS use w/ 16401301 16401406 $35.00
KNOCK SENSOR ADAPTOR 1 Knock sensor adpt. : 15900903 $19.80
RPM SIGNAL ADAPTOR 1 RPM adpt.: 6 cyl. (like Z33, V35) 15900904 $19.80
RPM SIGNAL ADAPTOR 2 RPM adpt.: 4cyl 15900905 $19.80
RPM SIGNAL ADAPTOR 3 RX8 ADPT. 15900909 $23.00
IGNITION SIGNAL ADAPTOR 1 Ign. adpt :6cyl 15900906 $19.80
IGNITION SIGNAL ADAPTOR 2 Ign. adpt.: 4 cyl. (like Evolution) 15900907 $19.80
E-MANAGE SUPPORT TOOL CD w/ spl. serial to USB cable 15901001 $139.00
