might be a stupid question... read some howto, none of them mention about grease/ antizeize
but i find the bolt in the center work just like caliper pin, if you grease the caliper pin, y not the mount?
so i come up with the question
do you or should you grease the bolt that run in the middle of the rubber?
and do you or should u anti-seize the bolt that bolt the mount onto the frame? easy to take them apart next time? (will this anti-seize make bolts loose over time?)
(i just had a bad time fighting the 10 years old rusted nuts and bolts (hand))
