blackdragon0731
- 2008 Mazdaspeed3 Grand Touring - Black Mica
First of all, I don't know if this is exactly the right section for this post.
Secondly, I haven't read this ANYWHERE on this site so I figured I'd share, if I missed it someone let me know.
After doing some reading and looking around, I've come to the conclusion that for anyone wondering where a good place to tap for a vacuum source, for installing gauges or an electronic boost controller, try putting either a single tee (if you only need one) or even using a vacuum manifold in-line with the brake booster vacuum line. That's a pretty damn strong signal and there should be no reason that teeing into it properly should do any harm, just make sure you splice it in before the check valve in the line (that should be no issue, the check valve is pretty far back).
I'm going to be trying this on this upcoming monday for my GReddy EBC so for anyone wondering how this works just stay tuned
For anyone worried about possibly causing a leak in the line and losing braking, just remember the brake boost is an ASSIST and merely assists the braking action. The check valve in the system keeps enough pressure to allow you brake normally until that retained pressure is lost, but you can still brake!
If this is deterring you, there are already a few points in that vacuum line that are coupled together from the factory, with clamps and everything, you can merely replace this inline coupler with the T-piece you want to use and reuse the factory clamps and everything, you should have no reason to have any vacuum leak.
