Fede_italiano said:Thanks guys.
This is a good discussion.
Sequential >> Batch
It's kind of a circular discussion in some ways... we are working with Microtech to get the units to be full sequential. I was told this batch was going to be, but long story there... word is roughly another month...
But there are three to 4 firing modes... group, batch, semi-sequential, and full sequential. These are how I describe them, there are futher variations of them though too (like group fire can be done every 360 degrees rather than every 720, or even every 180 degrees etc).
Group - all 4 injectors fire every 720 degrees, or essentially once for the time it takes for each cylinder to fire.
Batch - 2 injectors trigger at 0 degrees, and 2 trigger at 180 degrees and then not again for another 720 degrees
Semi-Sequential - (also called batch fire as well), 2 injectors fire at 0 and at 180 degrees, and do so every 360 degrees
Sequential, one injector fires every 180 degrees (not necessarily timed to line up with intake stroke etc... common misconception).
The difference between semi-sequential and sequential is so small that they become arguable... because sequential is more "advanced" people like to argue that it is better... there is in theory a 2-3% gain in some midrange power, but that is hard to measure dyno to dyno, and also, that could be running semi-sequential/batch every 720 degrees instead of every 360 degrees... keep in mind that when run every 360 degrees, every cylinder will get one injection that can be timed to go into an open port, and one to go onto the back of the valve.... this means you get additional valve cooling and vapor charging of the intake track, as well as the high atomization for good burn from the open port injection. In some ways this is arguably superior to sequential... what happens in a stock car on sequential is typically the injector is fired so that it COMPLETES it's injection right as the valve starts to OPEN... in race cars you do it so that you complete just before the valve closes which is what people think is "normal" but is not... so obviously hitting the back of the valve is not exactly a "bad" thing..
I have to roll... but I'll add and discuss more in an hour or so.
thanks,
Steve
