kanuter valve
- 03.5 msp
update: all it needed was a clutch pedal free play adjustment. took a 12mm wrench and 10 minutes.
sometimes i have to push the shifter very hard to get into 1st gear from a stop. 1st to 2nd sometimes grinds and 2,3,4 can be difficult as well. seems to get worse when it's hot outside and MSP has been running a while.
rear engine mount? slave cylinder? transmission rebuild kit? (selector hubs, synchros, bearings, seals)
What is the difference between selector hubs and gears? If rebuilding, do I need new gears?
