Gauge wiring questions
Hello everyone
First the vehicle I'm working with is a 99 protege 1.6l 5speed
I've been attempting to find wiring pinouts for the instrument cluster because Ive swapped in a instrument cluster from a 03 protege 5
The 99 instrument cluster is BJ0H B
The 03 instrument cluster is BL8R
The cluster works for the most part except no high beam light, no tach and temp gauge reads maxed out
So I know I have to repin the connector a bit and add the tach signal from the ecu but I can't find reliable pinouts for the clusters to do it can anyone help
Hello everyone
I've got these diagrams for the 2002.5 Protégé5 cluster.
I have no idea about the 1999 1.6l.
Hello everyone
you cannot swap a 99 cluster with any other year, it has to be 99 only. Mazda changed a bunch of s*** in 2000 and it's not backwards compatible. Even swapping a 01-03 cluster into a 2000 has problems
The cluster works for the most part except no high beam light, no tach and temp gauge reads maxed out.
Don't Use The Temperature Gauge on the Protégé5 cluster.
It's a dummy gauge and is F'-In useless.
It won't read hot until your head is warped.
Get an aftermarket temp gauge, or plug in the Torque App to watch your actual temperature.
