G35 Motor build progress (Lots of PICS)
boomergt
2003 Infiniti G35 Coupe TT;2003.5, Mazdaspeed Protege
Well guys as you know my MSP was sold on Monday.. I was sad to see it go.. But the G35 motor is going in the car this evening.. I figured I would post some pics.. Enjoy..
I added a ton of new mods...
GTM built short block with Eagle Rods and Arias ED Pistons
Competition Valve Job with Brian Crower Stage 2 Cams and JWT valve spring and shim kit
Cosworth Stopper Ring Headgasket VQ35 96mm
DeatschWerks 600cc Injectors
Forge Actuators - Blue Springs
ARP 2000 HeadStuds
Koyo Racing Slim 350Z/G35 Radiator 36mm core
NGK LFR6AIX-11
Revup Oil Pump
Defi Water Temp, Oil Pressure, Boost Gauge
Defi Link Controller
Lotek 60mm Pillar Gauge Pod (willow)
Dual Bank PLX Wideband (DM-200 + SM-AFR Combo )
Optima 34R
holy s*** Tom! I know you said you had more parts but DAMN!!
edit: you decided to go with Defi gauges this time eh? nice
Yeah... Got out of hand...
I did.. The defi gauges are too nice. I also already have the defi controller in the car. Then I have the one PLX gauge which will display both the wideband sensors.
The motor is in the car now and things are going well.. Here are some more pics.
Here is a pic of the car as we were moving it from storage.
i wish the entire front end would come off like that on the msp lol i wish i t would of done it on my old 240sx when i was swappin motors too
The motor is all finished and in the car. I need to get my O2 bungs welded into my test pipes then install my gauges.
Once I get the test pipes welded and the ems back I will be able to start the car. Hopefully in a couple days.
However I started another new project. We had the car up and were looking at the body kit paint and it was very bad.. So I am sanding down the rear lip and the side skirts to get them repainted.
Im looking at picking up the defi gauges for the new ms3, where did you pick them up from, i know there is a couple different sites. And maybe ill throw you some cash to install them, cause you guys deffinatly have a better facility then me and most of the board members
