fuse help
Furl
so i was installing my metra dash kit in my 06 speed6, well stupid me forgot to disconnect the battery and the wires that have a clip on it that clip into the dash and then wires off of it, touched. Pulled all my fuses that i could (some of the big block ones i cant tell if they are blown) My interior lights, radio, clock, keyless entry all dont work. Does anyone know the problem? I am going to call metra asap (maybe i fried on of those chips on the dash kit?)
Are you sure you checked the ones in the driver's side kick panel? There is a chart in the manual and it sounds like everything that isn't working is all on the same fuse. Look it up and swap it with another to see if everything works again.
yeah, i got it. the fuse actually blew out of the holder so when i was checking to see which one it was i didnt even see it. but i just took the spares and ran through the empty ones and found it.
