full size spare in the Protege sedan
sselander
I have a 1999 Mazda Protege ES.
I have just completed putting in a full size spare with no problems.
I sliced the three U shaped brackets holding up the donut with a sawzall and bent the metal back and forth until they broke free. This gives you a couple of inches and lets the wheel fit in the well nice.
I ground off any sharp edges and sprayed some rubberized undercoat in the well so it looks pretty sharp.
For a holddown, I used a wheel bearing cap and trimmed the flange off.
I then drilled a hole for the bolt.
I inverted it and used a rubber tub gasket so the metal would not rub on the alloy wheel.
I then shortened the original bolt since the stock was now to long
The carpet fit better without the cardboard underneath it so I left it out.
It fits well and looks stock. It does not stick up very much.
I was lucky to get 4 stock rims and 4 new tires for well under $200
I only needed one for a spare but I couldn't pass up the opportunity.
