719prottege
- 03 msp
So i got everything back together in my car, blew my last motor up. now the fuel pump wont prime in the key on position and when i crank it no spark. i cant seem to find anything unplugged anywhere, i swapped the ignition relay with the ac relay and nothing different. any other ideas? grounds i may have missed, plugs that are hard to see i might have overlooked? swapped out the crank sensor with the one from my old motor, and the cam sensor also, but even if those were bad, the pump should still prime, right? gonna work on it tongiht, please give me any ideas you might have while im stuck at work.
