MacProtege5
i have a 2002 protege5 and i was using a 75 shot of nitrous with the zex kit and it felt like the engine was misfiring really really badly, so i stopped the engine and coasted off the road. i was using NGK spark plugs one range colder then the stock plugs, i was also using a high flow msd fuel pump. i also have NO ignition upgrades besides the plugs. i got the car towed home and took the spark plugs out, and the plug closest to the driver side was blown apart, the white plastic or ceramic piece was blown apart into several pieces, then i proceeded to look into the spark plug hole and saw piece of metal in there. i then took off the exhaust manifold and also saw pieces of metal on top of the catalytic converter. the pieces of metal are flat, and about 1/4" in size. could anyone tell me what happened? could it be detonation? any help would be appreciated
