FS: used ETS 3.25" TMIC - sold
Status
Not open for further replies.
SSMS3
'13 CWP
No issues, no broken tabs, plate is trimmed to prevent potential contact and haven't had any.
SOLD
How many miles was this on? Does it come with install instructions or are they readily available?
Edit: PM Sent.
^ PM replied!
It does not come with instructions but install is very simple. Maybe a half hour if you take your time. Once you remove the stock ic, everything makes perfect sense. If you're concerned I could put something together for you to help guide you through the install.
This also a good time to install an aftermarket BPV (if you haven't yet). Shameless plug, but I'm also selling my Forge BPV in the main classifieds section
I will buy this from you. I already have a Forge BPV though :)
We can work out the details through PM.
It looks like it just bolts right up. Do I need any gaskets or anything else to install it? Or can I just slap it on? Also, are you certain it doesn't leak?
No problem, thought I'd ask.
There is one gasket you reuse but it's very durable and you shouldn't have an issue. Yes, I'm certain it does not leak
Status
