FS: OEM Mz3 Heated side mirror glass (pair)
Status
Not open for further replies.
icspots
Paramagic
2012 Mazda 5
SOLD: OEM Mz3 Heated side mirror glass (pair)
Up for sale are left and right OEM heated side mirrors (p/n's BP8M-69-1G7, and BP8M-69-1G1) for the Mz3. I installed these last winter using THIS method.
All US Mz3/MS3's with power mirrors are compatible with these mirrors, however you will need to run wire from the glass to the plug and insert some new pins (covered in the walkthrough linked above). It's a very easy install and should take under an hour for both sides. The glass comes on with the rear defroster and works perfectly for both fogged up glass and ice.
I'm selling because I just upgraded to wide angle heated mirrors. New they run $41/side, I'm asking $60 shipped to the continental US. I'll include wiring with connectors attached so all you need is solder and a pack of $.99 diodes to use as pins.
Status
