FS: BC Racing Coilovers
Status
Not open for further replies.
Rogue
Red 5 Standing by
Contributor
2003 MSP
BC Racing:
BR Type Coilover Suspension - SOLD
Application: 99-03 Protege / Protege5 / Mazdaspeed Protege
Price:
$800
Spring rates:
Front Springs - 8kg/mm (~448 lb/in.)
Front Struts - valved for 8kg/mm springs
Rear Springs - 6kg/mm (~336 lb/in.)
Rear Struts - valved for 8kg/mm
Extra Springs - 10kg/mm (~560 lb/in.)
These have been on the car for less than two years. The rear struts were replaced with softer valving in July of 2009. So there's less than 20K miles on the front, and ~5K miles on the rears.
With the way BC struts are designed, you can run spring rates that are +/- 2kg/mm of the original valving. So, the rears are valved for 8kg/mm springs, but I'm running the 6kg springs. If you want to run the stiffer springs in the front or rear, the struts are valved to accommodate the stiffer springs. You could run 10k/8k F/R if you wanted, as the springs are the same length.
Front struts come with camber plates with pillow ball mounts. Rears only have pillow ball mounts. Both the front and rears have camber adjustments at the bottom where the strut mounts to the knuckle. The upper hole is oval allowing camber adjustment. I've had -2 in the rear from just using those to adjust camber.
Pricing
Price does not include shipping.
Payment
No dibs. First person to send payment is the one who receives the parts.
Send paypal payments to millah at gmail dot com. No checks. No money orders.
Rear Springs Rate
Extra Springs Rate
Front Spring Rate
BC Racing Part Number (E-03)
Official BC Racing Decal
Strut tops
Close up of Strut Tops
Close of where strut mounts to knuckles
I will get these boxed up soon to be able to provide shipping quotes.
Duuude! Damn i wish i had known u were gonna put these up, i would have put some money away for them....sigh
I'm open to reasonable offers.
Kevin, want to put down a deposit? :)
I wish I could buy these but I can only afford to buy some lowering springs. I'm currently looking for some to lower my car
i wish i could too, i'm planning on getting these, just prob in about a year or so, i'm looking at new engines and some of them are quite expensive, so i'm saving for that... sorry
cain even believe nobody has swiped these up yet. bump in hopes someone putting these to good use.......and join the slammed crew(hi)
dangit, each day i see it still it still up for sale i cry....wish i had moneys T_T
I need these gone. Shoot me a number.
$50? i dont mean to offend you, thats the best i can do for them at the moment. seriously, i cant afford them, or offer you something that would be mutually acceptable.
Status
