FS: 2003.5 Mazdaspeed Protege
SOLD
128,000 miles.
Everything it needs:
Minor damage to hood as seen in picture, front cross member slightly bent. Someone backed into it and the damage is purely cosmetic.
Driver's lower control arm makes a little noise over bumps.
Small exhaust leak from manifold or gasket.
Just started to make a squealing noise (not too loud) when turning steering wheel at take off.
Will need front brake pads soon.
Stumble at 4k sometimes. Knock sensor is melting, have a new one in hand, not sure if this will fix it.
Mobil 1 full synthetic every 5k since new. Up to date on all scheduled maintenance except brake fluid. CustomMSP SMIC, Vibrant stainless exhaust, Exedy Stage 1 clutch, Auto Meter Ultra-Lite boost gauge, AXR clunk fix bracket, SU front motor mount, Kartboy shifter bushings, ATP WGA. 27/31 mpg.
$4,500 firm
