I took the beater 626 yesterday to give it to someone and discovered the cooling system had frozen, not enough anti-freeze. I put it in the garage to heat it up and it seems ok except for one thing.
It is missing one of those round metal disks that they put in to seal up the engine block, they look like they are aluminum. There is coolant leaking from here. I looked for the missing disk, but didn't find it anywhere.
My questions is, is there any way to easily replace one of those little plugs? I can only assume that it was pushed out by the ice, so I can't imagine they are welded in. But, given the heat, I am not sure how they are secured.
The car has 220,000 miles on it, so it isn't worth doing any major work, but if there is an easy fix, I would love to hear it.
E.
E.
