Hello
I have our 2009 CX-9 apart for a wheel bearing replacement. Everything is apart but I cannot pop the lower ball joint out of the knuckle. If I cannot remove the knuckle, I will have to attempt the bearing R&R with the knuckle mounted instead of taking it to a shop with a press. I have the Harbor Freight version of the OTC Hub Tamer that I would use and new Timken bearings.
Is there a DIY writeup online that outlines this procedure?
If anyone could post the torque specs for the lower pinch bolt, halfshaft nut, caliper bracket bolts and strut to knuckle bolts I would appreciate it.
Thank you!
Ian
2009 CX-9 GT
Thank you!
Ian
2009 CX-9 GT
