Front speakers
A while ago someone posted links to tech pages for removing the rear interior mouldings (specifically where the rear speakers are) does anyone have instructions for accessing the speakers in the front doors? Does the whole interior door panel need to be removed or can the speaker grills be removed to access the speakers?
Was98strat,
I just did my speaker install yesterday. The whole panel needs to be removed. That's the only way to access the speakers. You also need to remove the small sail panels near the side view mirrors and remove the screws holding the power switches and door lever.. Be careful with the panel pins.
Undo the screw in the door handle. Lift up the silver piece by lifting forward It think? Then, there should be another screw inside. Unplug the window hardness. Then, you need to pop off about 8 or so pins every 6" or so around the door panel. Carefully if you don't have the tool. Then, remove the tweeter front, then the panels lifts up and off taking not of the dangling tweeter.
