front door panel removal
qluber1
2008.5 Speed3 GT
does anyone have details or pics of how to remove front door panels for speaker replacement? sorry if this is a repost...
-Remove the screws behind the door handle, and the door release
-Remove the "bowl" behind the door release
-Grab the door panel and pull away from the door to release the plastic tension pegs. They are along the bottom/sides, and there are a few in the center. There aren't any along the top edge so don't pull there. ;)
-Once all the pegs are released slide the whole panel up to release it from the window channel
-Unplug the wiring harnesses from the inside of the door panel
-set the panel aside and you're done.
..thanks a ton(p5black)
