mazdadude
ZOOOOOOOOOM ZOOOOOOOOOM
- '16.5 Mazda CX-5 Touring
From Yoko to Yoko: 17" Tire replacement review Yokohama Avid Ascend 225/65/17 102H
After many sleepless nights regarding tire replacement, I decided on replacing the stock OEM Yokohama GEOLANDAR G91A with a tire tuned for more highway and comfort, with greater traction, and better treadwear, under 28lbs each, AND wanted to spend under $120 a tire. In the end I decided on the Yokohama AVID ASCEND 225/65/R17 102H from tire rack. Had them installed at my 22,500 mile service at the dealer. Original tires were at and wearing the wear-bars.
Original treadwear/traction/temp rating for the 225/65/R17 100H G91A was: 280 B A, 26lbs, 10/32 depth.
Replacement 225/65/R17 102H AVID Ascend tires are: 740 A A, 28lbs, 12/32 depth.
Also the tires were made (this tread size) in USA.
So far after 300 highway and city miles, there are no negatives, only positives. They are softer riding over imperfections, there is a supple rubber feel back in the suspension, highway speeds are much quieter, and traction is improved both in the wet and dry.
