- 2001 Mazda MP3
http://shawnkubik.home.comcast.net/rx7/index.htm
i'm jealous
hes going to pull out the rotary and put in a LS1
i'm jealous
Surface rust. Will come off when he applies the brakes.mazpro said:seems to be great condition, exept for the rusted rotors....
JCell said:i wouldn't put an ls1 in it either, the rx-7 may not be the fastest thing around, but being so lite has othe benefits
Wankel engines have several major advantages over reciprocating piston designs, in addition to having higher output for similar displacement and physical size. Wankel engines are considerably simpler and contain far fewer moving parts; for instance, because valving is accomplished by simple ports cut into the walls of the rotor housing, they have no valves or complex valve trains; in addition, since the rotor is geared directly to the output shaft, there is no need for connecting rods, a conventional crankshaft, crankshaft balance weights, etc. The elimination of these parts not only makes a Wankel engine much lighter (typically half that of a conventional engine with equivalent power), but it also completely eliminates the reciprocating mass of a piston engine with its internal strain and inherent vibration due to repetitious acceleration and deceleration, producing not only a smoother flow of power but also the ability to produce more power by running at higher rpm. In addition to the enhanced reliability due to the elimination of this reciprocating strain on internal parts, the construction of the engine, with an iron rotor within a housing made of aluminum which has greater thermal expansion, ensures that even when grossly overheated the Wankel engine will not seize, as an overheated piston engine is likely to do; this has substantial benefit for aircraft use.
The simplicity of design and smaller size of the Wankel engine also allow for a savings in construction costs, compared to piston engines of comparable power output.
As another advantage, the shape of the Wankel combustion chamber and the turbulence induced by the moving rotor prevent localized hot spots from forming, thereby allowing the use of fuel of very low octane number without preignition or detonation, a particular advantage for Hydrogen cars. This feature also led to a great deal of interest in the Soviet Union, where high octane gasoline was rare.
Captain KRM P5 said:keep the rotary and leave the LS1 for the F body boys
spacemonkey said:I also have video of the scoot 4 rotor...26B. Thing was amazing in that it almost sounded like a motorcycle. Rumor has it that they have plans for a 6 rotor.
spacemonkey said:Its not the lightness...its the compact design. The rotory engine allows it to be mounted futher back and lower to the ground then most engine.....low center of gravity and good weight ditribution.
spacemonkey said:...and I would like to see a pushrod V8 have a broad power band like a rotary engine....A Rotary engine has peak power at 8500 rpm and with certain flashes can be raised to 9000 rpm...now that is a broad powerband. Also I would like to see that V8 have such a smooth power band and the willingness to rev as good as a rotary engine.
