FP Reduction kit installation question
tweaker
yeller mazdaspeed protege
a couple of questions regarding the kit...which line is the fuel pressure regulator line...and drilling the hole in the plastic intake pipe...I run a Injen CAI...does the hole need to be drilled into that or am I just a dumbass? Any info will help me out here...thanx
hey man! T into the fuel pressure vacumn line off the regulator. then run a line off the check vavle and drill a hole into the injen intake after the maf senor about 3 inches back. this is the closest to the turbo.
email joe p if you have anymore problems.
thanks justin
