twelveinch
I'm a heavy poster over at ************ and I thought I post this here to if anyone could shine some light:
OK guys, I posted this thread in the modifications but I thought I should post it here too.
We finished my speed a couple days ago, my tune was set for this Tuesday, and since that time the car was being driven slowly to "break some of these parts in". I was using the Dashhwk to monitor everything and everything was perfectly fine: fuel pressure, adv. timing, throttle, etc... everything was running like when the car was stock.... for the most part.
Nevertheless, yesterday, I thought I would finish my angel eyes. I had the fuse go out on the angel eyes which I have everything in the fuse box and under the fuse box. Well, when I was done, I went to start the car and the car keep turning but it wouldn't start.
a) a this point I was showing for codes on the Dashhawk, the malfunction indicator light didn't go on, the fuel pump was working, etc....
b) sorry I don't remember the codes but the first code was:
code1: P2128 (TP) sensor/Switch E circuit high input
code2: P21?? unknown
code3: P???? actuator
code4: P???? something to do with fuel pump rail 1 or something
The reason I can't get the exact numbers is because I can't get the Dashhawk to connect. When I connect it tells me to input vehicles specific PID's and when I do it gives the following error:
"ERROR: CAN communication not found. Either the ignition is not on or the vehicle does not support CAN communication"
The CAN error and the malfunction indicator inside the car happened after a few hours when the car wouldn't turn but tried too. Meaning, as the day progressed things got worse, a whole lot worse.
All the work before this horror happened was around the fuse box. Don't ask how, but the blue lever harness going into the fuse box is stuck and won't come out as well? WTF? When my buddy came by we disconnected everything- throttle senors, ecu, grounding kits, etc waited about twenty minutes and connected everything back.... nothing. Then, we proceeded to move around the cables underneath the fuse box as it is highly susceptible that one of the pins from that harness/relays came lose/undone...then I also left the battery unplugged for about an hour.... when we connected the battery back up (after it was disconnected off and on a few times to troubleshoot) I got the malfunction key indicator light and when I go turn on the ignition- nothing- it beeps, but when the key turns the fuel pump won't go on and when the car is started it's silent.
So, troubleshooting 101:
I checked all the fused yesterday, inside the engine compartment and inside the car, and all are in tact. The next thing to do is check all the relays.
I will have to somehow get that fuse box blue lever harness out and checked to make sure none of the pins got bend or fried. Then, I will have to check the ECU pins (160) of them for continuity- see if the resistance is off as that will tell me whether or not the ECU is fried... but this is highly unlikely. The worse case scenario, yes, but what it could also be is that the ECU lost its codes later at night too when the battery was being disconnected a few times.
Is there some type of fuse (on any of the harnesses) or some master shut off switch? The reason I ask is because when my friend's SABB wouldn't start (everyone thought it was the starter/battery) after those got replaced we learned that on the positive battery terminal there is a switch that was popped due to overload...and all we had to do was push it back in.
Any help would be greatly and highly appreciated it.
Thank you,
Sebastian
Thank you,
Sebastian
