LinuxRacr said:Haha.... it NEVER goes away. You will always hear a slight chatter with these because they were not designed to be quiet. Very low silicone content. If you are worried about noise, I would go with Wiseco, or SRP pistons.
The pistons are noisiest on cold startup. After they warm up, the loud diesel sound turns to a low chatter.
One way to combat this is to get your pistons coated on the skirts with a Poly Moly coating from Swain Tech. This would make them quiet. While you're at it, you may as well get your piston top heat coated to reduce cylinder temps.
How much does the skirt coating cost?
