i wouldn't think it would have to do with adjusting the spring I believe its by shortening and lengthing the arm changes the boost. , because by shortening the arm you are putting more tension on the wastegate in return needs more boost to open it up, and lengthening would decrease tension on the wastegate needing less boost to open it. im running a stock t25 WGA on a gt28rs but it was too short and needed lengthened to fit, while i installed it it was still a tight fit putting some extra tension on the internal wastegate so therefore i am running about 13psi instead of the stock boost. Also i believe the only reason my psi is high from extending it is because if i left the stock length i believe i would have been running a lot higher of boost than i am now.
In no way am i experienced with turbos as this is my first boosted car, i am only speaking what i believe i have learned from my own experience
