Forge bpv help
Don't over think this one. Try blue with 2 shims, see how that feels, go from there. It's not rocket science.
The BPV does not control the level of boost you see, regardless of spring. The spring is only affects how hard the valve bangs open and shut under vacuum.
If it's leaking you might see lower boost levels but, that's because it's leaking.
