Installshield 2
Gothenburg Superiority
So in short, from what I read, these are great for the front.
Is there any better replacement for the back sway-bar links?
What does everyone recommend for replacement for the front and back, there were more options that I thought available
I was sort of touching on that in my above post...as of now, there are no true 'upgrades' for the rear of any Protege from what i can tell...There are adjustable rear endlinks available from AWR...but i've read multiple posts from users saying its far form an upgrade, constantly need to be tightened, and that the adjustable nature is only valuable in racing applications...plus, they are far from cheap.
The situation with the rear is annoying, too...To my knowledge, the MSP and MP3's both use a rear strut setup with a different end link mounting point...i've never seen them side by side...but its been confirmed multiple times that those cars spring perches are different, and that the strut tube was changed slightly...all of which would make a different endlink flange plausible...
So these cars use slightly longer rear end-links than that of the regular sedan and p5...They are not really upgraded or anything, just longer, and WILL NOT fit on a regular sedan or P5...they push the sway bar down into contact with the rear control arms, and will make all kinds of noise because of it...
the factory P5 rear endlinks are 184mm iirc...so when sourcing parts, be sure of that measurement...the links in the ~190+mm range won't work, just went through this a few weeks ago...but even the dealership was trying to sell me the wrong size after taking the VIN from my car...not sure where the parts database got so messed up, so just be ready to check the size at the counter when replacing the rears...
