I was looking at this as a possible option, along with going at the back of the block. How does the heat from the turbo treat your sender? Wires look like they have been a little "warm."PaulMP3 said:Mine is on the oil inlet for the turbo.
Can you explain how you went about relocating the sender.deckedoutmp5 said:be careful when mounting it with the stock sensor, you can get a short if your starter hits it, there is little room and when you put the sensors and t on there it makes a lot of weight and the npt fittings are not very strong so be really careful when tightening and stuff.
EDIT: i moved mine so it was easier to get to, its on the pass side firewall.
