Fogs on with parking lights and high beams...
Of the three ways I posted in that thread none of them turn the fogs off when the high beams are on.
Method one "the jumper" removes the fog relay and runs a single wire from one of the relay's spots to a hot unused fuse spot. The fogs will be on at all times when the car is on regardless of the position of the fog switch.
Method Two "the relay rewire" removes the fog relay and changes where some of the terminals connect by running wires. One goes to the same hot fuse slot used in method one, and another is run through the firewall and tapped off of a wire in the steering column. The fogs are on whenever: A) the ignition is hot, and B) when the fog switch is on. Note this method doesn't work with OEM HID equipped Mz3's.
Method three "the fuse box rewire" reroutes/taps off of wires in the passenger-side fuse box inside the car. Basically cut a wire and tap it off of another (choice of two depending on if you want them on with the car or with the parking lights), then cut two more wires and connect them together. The fogs are on whenever: Option A - the ignition is hot and the fog switch is on, or Option B- the parking lights are on and the fog switch is on. http://www.mazdas247.com/forum/showthread.php?t=123708442
