http://web2.airmail.net/theman/mz3fog
(fu) computer controlled lights bulls***! so much work just to bypass that pile of s***!
TheMAN said:this mod is also illegal in MANY states
sorry, you can't just install a separate switch to the fog lights without running a completely new harness DIRECTLY to them... your "safe way" still means having to **** with the PJB..... this mod simply bypasses the CPU control of the fog lights and as long as you are very meticulous about rewiring everything, you should have no problems down the road
TheMAN said:mind sharing your PJB experience?![]()
TheMAN said:so you cut the wire BEFORE the PJB/fuse and fed power to there or AFTER it and installed a new fuse holder? I don't see how any of that could've caused the CPU to be fried
Yeah. That's exactly what I said, too. The tech said, "You made modifications, so we're not going to warranty it" and just shrugged his shoulders as if to say, "Too bad. What're you gonna do about it?"TheMAN said:I don't see how any of that could've caused the CPU to be fried
goldwing2000 said:I cut the wire between the PJB and the lighter and fed power in directly to the lighter.
I bypassed the PJB. I took it apart and realized that there was no way to re-route any of the power inside since it's all on a printed circuit board.
TheMAN said:so you ripped apart the PJB before it fried or after the fact?
yeah.... getting all this s*** to work is a major PITA... I'm going to say the protege is WAY better to work with!
TheMAN said:http://web2.airmail.net/theman/mz3fog
