Fluctuating RPM
Hi there,
I have been witnessing fluctuating RPM since 4 months now on my 2019 CX9 that has 130k on the clock. The RPM keeps on going down then back to normal occasionally. I replaced sparking plugs, air filter and fuel filter. I'm thinking to reach out to the throttle and clean. Before I do so, has anyone gone through the same symptoms? If yes , what was the solution.
Thank you,
It is known to do this with the AC on. It cycles a few times per minute.
