Flashing Radio Lights
RCC
I was driving home tonight and the lights on my radio started to flash. Not in the radio display but below that on the radio controls. With the car not running and the lights on there was no flashing. I'm thinking it might be some sort of a ground problem. Has anyone else had this happen?
Try rotating the dim rotory switch on the dash completly to the right...this will max out the brightness and see if your switch is defective. Once its max'd out see if it is intermittent or not...I had this issue on my 5 also.
Alright, I'll try that. But with yours was it all the dash lights or just the Radio?
Was the radio but once in a while the center dash lights....
Also I have seen a connection of that radio display to be intermittent also...
I turned the dimmer all the way up tonight and no flashing. I didn't turn it back down a bit to see if it started again. I probably should have.
