Called to find out how much it is. $180. I'm planning on finally getting my suspension fixed, so I'll need an alignment. So you guys think it's worth it?
Yes, it's absolutely worth it. You should also get lifetime rotation included with that as well. Here is a $20 off coupon that I found for any location (you just have to print it off). It's only good for today though apparently. http://origin-cdn.coupons.com/static/ext/coupon-codes/pc/546966_2.gif Good luck !
Bear in mind that what you are getting in a free "alignment" only, not any associated services that they may decide you need after performing your "free" alignment. It is first and foremost a way to get you in the door and get your car up on the rack. Yes 180 bucks is a good deal to align the car for as long as you own it. Just be wary of shysters trying to rake you over the coals for little (or big) stuff that they "find" in the process.
