Finally! $600 ready for spending
haha i saved up since probably 7th grade for a car and i had my eye on an evo VIII but then i saw my first speed 6 and test drove it and fell in love with it then did some searching and found the one im in now and i would have already made my decision if i hadnt just broken my left rear axle or one of the things it connects to inside the diff a few days ago...no idea how it happened i was just driving then SNAP
Okay so here is what ive decided on:
http://www.protegegarage.com/product_info.php?cPath=34_267&products_id=610
first is this set of springs because i get a 1.5in drop in front and a 1.4in drop in the back plus they are pretty cheap
http://www.protegegarage.com/product_info.php?cPath=34_420&products_id=644
next is this rear motor mount due to high recomendations
http://www.***************/**********_Differential_Brace_p/sums6rdb.htm
and last is this diff mount i decided on this one over the cp-e one because of the price but if im making a bad decision let me know
all together this should cost me tops $500 but my friend JP at Edge Autosport may hook me with these parts
if there is anything im missing let me know please
If I remember correctly, the Eibach springs aren't fitted for the speed 6. They are generic for the 'Mazda 6,' although I may be wrong there. I would look into H&R Springs or the RPM Springs. Both are designed for the MS6 and give good drops.
The Eibachs aren't made for the MS6, don't cut corners to ruin your suspension. Get the H&R or RPM springs instead. The motor mount and diff. brace are good investments as well, you won't be disappointed.
Sounds good ill check the rpm and h&r ones out but im also thinking of adding a SU test pipe because ill still have just over 100 to spend
