Schwacofer
- 2014 Mazda CX-5 Touring
Final check before I start my install: 2014 w/BOSE & trying to keep full HU function
GOAL: Keep all BOSE head unit, steering wheel controls, backup camera, USB & AUX
In that goal is also to keep the center channel processing that BOSE provides.
This post is an extension of one I made a while back and uses some of the information from this post by jlcpremier
CDT ES 3 ways will be the left and right main speakers and a matching CDT ES 2 way will make up the center channel.
Since the BOSE processing treats the Left and Right dash speaker as tweeters (they are crossed over from the doors speakers at ~3khz within the amp) AND because the HU appears to out put a line level signal, that output can then easily have RCA ends attached and connect directly to after market amps.
https://www.amazon.com (commissions earned)
The bit of "ghetto rigging" now will be in getting the center channel output to work because that it controlled though processing on the BOSE amp AND getting the full range single from the stock HU into the amp.
My thought then is to split the bare wire output form the stock HU and have 1/2 go to the after market amp and 1/2 go to the BOSE amp so that it can continue to do the center channel processing. The speaker output from the BOSE amp will then be converter to line level though a basic Kicker LOC and then fed into after market amps.
Has anyone tried such things, or does anyone see any issues that I might not be considering here? I figure the output voltage from the HU will be cut in 1/2 but I am hoping that the original output strength is enough that it wont be an issues.
