Fatti's Renesis powered FC
fatti03msp
Contributor
03 MSP & 91 RX-7 & 00 1500
Like the title says...... Thanks to my roommate Sen2two who did pretty much all of the research and testing, Ill be finishing up the project he stated.
The car..... 91 RX7
shots for the renesis bolted up in a Sen2Two's FC.
Some quick info.
6 Port renesis core
1st gen front cover
Custom Oil Pan w/ custom oil baffling - Made by Sen2two
Custom Motor Mounts - Made by Sen2two
The Build.... we are going to try something a lil different on this motor.
Going with a peripheral intake with a custom made Sliding throttle body, and we are going to try bridge port the exhaust. We know it runs into a coolant passage so we will fill the areas that are needed filled and it will be good. Lets just hope it will be beneficial.
The goal is for a min. of 250whp NA which i thing will be easily reached
Nice job on the motor mounts. And I thought something looked "odd" on the front of the block.....that front cover. I think I'd skip the bridge port. Can't remember for sure, but I kinda think that someone experimented in that direction (PETTIT maybe?) but decided it had more risk than benefit. Regardless, looks like it should be fun car.
I know you didn't get alot of response, but update the thread when you can. I'm interested.
all the fab parts are awesome sen2two def. has some fab skills, but ill def. be updating the thread. Have alot of work to do to the chassis too.
Going to buy some dry ice and remove all the sound deadening from the car. Pick up an aluminum dash form jegs and get that mounted up along with some door cards too.
also think im going to try out a megasquirt setup.... Still need to read alot about it though.
