Ive installed Falken Azenis 235/40-18 on the stock wheels. I was concerned about the narrowness of the stock wheel, but the tire shop (owned by enthusiasts with plenty of track experience) said there would be no problem. Of course, there would be a slight deformation of the sidewalls and consequently a slight deformation of the tread, but they felt this could be reduced or offset by running slightly lower pressures.
In any case, the Azenis should way outperform the OEM BS Potenza RE050A tires. Ive run two track events w/ the RE050A tires, and theyre pretty miserable as well as being way, way overpriced.
So, how do I like the Azenis (Ive had em on for four weeks) compared to the RE050A? (1) The grip is much, much better. (2) The ride is slightly better. (3) Torque steer is slightly reduced (because the Azenis are stickier and wider). (4) The Anzenis are a tiny bit noisier but only tiny bit, and after a couple of days you dont notice it. (5) The Azenis ought to last longer.
A whole lot better tire for a whole lot less money . . . whats not to like?
