can go either way. If the dirt was the crankshaft, the oil flows into the crankshaft from the main bearings. Then it would push the dirt out of the crankpin oil holes. If the dirt was in the block oil galleys then you would have both the mains and the rods looking like that.TurfBurn said:if the rod bearings look that bad I wonder how the mains are doing!!!???
But as it stands now the whole engine will have be cleaned out.
