exhaust manifold
jmo
I am new to the mazda protege world, and along with the protege 5 I got a turbo off of a msp. I was wondering if anyone knew where I could get an exhaust manifold that would accomodate the T25? Any recommendations would be appreciated.
thanks,
Jmo
We have the manifold that fits the t25 to the engine. It is cast iron and can be ordered with or without the port for an external wastegate.
Juan
Juan
that is awesome, this really helps me out... how much for the manifold, and also do you sell the down pipe, or at least something that connects the exhuast to the cat? Once again thank you
jmo
thanks,
Jmo
We have a log style manifold that is 3/16" thick stainless steel.Then we have it ceramic coated for great looks and to help with the heat.
Here is a picture.
prices
How much do both of your manifolds cost, how/where can I order, and do either of you sell any pipes that could connect the manifold to the cat, or sell a downpipe to bypass the cat? I would like to thank both of you for actually responding, this is the only forum I've found actually willing to help.
jmo
jmo
Yes, we sell the downpipe.The Manifold is $379, downpipe $359, midpipe range from $129-$269.
The manifold is $350.00, downpipe is $220, which consists of two parts, one is the actual downpipe and the other that connects from the downpipe to the donut joint. The midpipe is not available from us, but will fit any other aftermarket midpipe.
Our manifold is a 4 into 1 design with high flow and good spool up response. It is cast so it has a lifetime warranty as well as the downpipe.
mazdaman_49 said:
The Mentl Add Motorspts manifold looks AWESOME!
Hiboost- what happens if my cast iron manifold were to crack, like the aftermarket one on my nissan?
Like I said, they have a lifetime warranty. If it ever cracks, it will be replaced for free. All our castings carry a lifetime warranty.
Juan
Juan
the T25 off a msp has an internal wastegate, correct? So I wouldn't need the external port?
jmo
