daniel323px8rs
- Mazda 323 BA P
Hello, the Evo calipers fit with some work the BJ steering knuckle but you can not use with the EVO brake discs because the EVO discs are 320mm and you need 330 discs to use the EVO caliper with the BJ knuckle. The Evo discs fit the BJ HUB only with modification, the center hole is to smal, the must be 2 mm bigger. So I take some Brembo calipers and selfmade holder to fit my 323 BA P with FS swap.
Youn also need 20mm spacers.
