I have an annoying ticking/rattling noise coming from my engine. When my car is first started after being cold, it rattles really quickly and then stops when the engine begins to idle and warm up around 2000 rpms. Once the engine has settled down, the noise is nonexistent until I put it in drive and begin to use the gas pedal. The noise typically comes back closer to 2000 rpms while driving in any gear but 5th, but the longer my engine runs and the warmer it gets, the sooner the rattling comes when rpms are raising. I can also hear it cruising on the intersate in 5th gear doing 70 at 2500 rpms once the engine is at operating temperature. I originally suspected the timing chain, but I bought a valve cover gasket so I could check the chain and found out after pulling the valve cover that my timing chain is nice and tight like it should be. I am clueless as to what else could be making this noise. Any help?
