Boilermaker19
- 2003.5 Mazdaspeed Protege
So the last few days, my MSP has started sputtering at idle. It doesn't do it all the time, it will idle fine for a while, then it starts dying, chugs a bit, then will suddenly roar to life on its own. Also happens at low RPM. once I'm above 2000, everything seems fine. This is especially problematic given the iciness of the roads. The only CELs I have are O2 sensor-related, and have been there since I bought the car, and probably have more to do with the lack of a Cat than anything else. I would think IACV, but that should throw a code. When I monitored O2 sensor voltages, they were not erratic. The "absolute throttle position" reading on my OBDii analysis software, however, is at 10% when I'm not touching the throttle. Shouldn't it be 0%? I pulled three of the plugs (ran out of time), and they looked okay, just a little white powdery, possibly running lean, i guess. I am planning on Seafoam and plug change this weekend, but the erraticness makes me think that it's not just dirty injectors. I'm running FMIC with a BOV, SSAFC running the winter FMIC tune from here, and a 3 inch catless exhaust, forged internals and 9 pounds boost.
