Engine rattling noise issue. Can someone tell me what is making this noise?
Facebook video does not play for me. Without being able to hear it I speculate it may be one of the accessory belt pullys.
There is a belt tensioner and a separate idler pully and there is a bearing in the AC clutch that can all make noise at idle.
If it is one of them you do not want a failure to throw the accessory belt, because your water pump is driven by that belt. If it stops, you quickly overheat and damage your engine.
