I'm not thread jacking... you are in the same boat as me... mine starts at about.. eh.. 2600ish and stops at 4 ( maybe idk.. i cant hear it over my intake and exhaust... then comes on again at like 5000,
i have had this problem for about 3 days.. ,maybe 4 days... bave 83319 miles on mine...
things i have tried that have made a LITTLE difference...
#1 SEAFOAM... I used 3 bottles of this stuff... did it three times
#2 changed oil, ( i run synthetic, royal purple for now)
#3 changed oil filter
#4 changed plugs.. ( needed to anyways.. thought it might work.. but it didnt
#5 called mazda and asked them... they said get a stethascope, and listen to the block... did that... it is DEFFINATLY my number 1 and 2 cyc valves
#6 called mazda back and talked to a rep. in the service department... he said it should be adjustd.. 799 for labor.. or some steep price just for labor alone...
#7 SEAFOAMED if again.. just incase....
#8... checked the forums......
so far NONE of these have solved my issue.. I am considering buying cams, new springs and valves and all the goodies all togather just to get rid of it.. however that would not be the right thing to do with little money.. maybe these things will help you narrow down what is wrong with your car??
again... im not trying to thread jack..
