I have a 2003 P5 with about 224,000km, did a engine flush a few weeks back and now I get a tremendous amount of engine shake.
so I put the flush solution in the engine and ran the engine at 2500 rpm for about 10 minutes. Flushed it out and did an oil change. The directions on the bottle said nothing about keeping it at 2500 rmp but I did it anyway. The oil hasn't been changed is so damn long thought it would help. Also directions from a guy on Youtube.
The car runs fine, Idle level is good, but the shake, feels like I'm rolling around in a motorcycle. Is there anything I should check that would cause this? I may have too much oil but not by much. Would this cause it? I may flush out this oil and add the right amount once again. The oils not very clean, even after the flush. Still quite brown. It's also really hard to tell if the oil level is good from looking at the dip stick.
any input would help.
Thanks
New to the forum btw
Thanks
