Can anyone help here....
I am finding that i start my mazda 6 diesel estate in the morning and then within a few hundred yards - it cuts out when you take you foot off the accelerator pedal (after some seconds). The fuel sediment light then comes on - which i think is normal when the engine is not running.
Once restarted, it normally behaves fine and there is plenty of pull in the car etc....the problem seems to be when the engine is cold only and its guarenteed to cut out probably once everytime.
I had the sediment light come on a few months back so i took off the fuel filter and drained it but didnt notice any water in the diesel. Put it back and all was fine until now. So....i have just changed the fuel filter again and found no water in there.....so i have now ruled out the filter and sediment light as a cause.
Could it be the engine temperature sensor? If so - does the car have a seperate sensor for the management system compared to the dash indicator - because the dash indicator behaves normally.
Also - i always do my own servicing and drop the oil every 8000 miles. I have never had anything reset on the management system....is there need to on a pre facelift model?
Thanks in advance.
Thanks in advance.
