Engine bay detailing tips?
sunrun176
2008.5 Mazda3 Hatchback Touring AT, Copper Red Mica
Anyone?
I'd like to be able to do this myself instead of paying $$$ to have someone else do it. So, those of you who've done it before or do it a lot...
- What do you use, product- and "tool"-wise?
- What should I be sure to cover up to prevent it from getting wet?
- Etc.
Much thanks in advance. :D
take off any engine covers, clean those separately.
-citrus based cleaners and degreasers. small-medium soft brushes for hard to reach areas, nylon and hard bristle brushes for rust/heavy grease. protectant to help maintain the look after the cleaning.
-cover any air intake openings and sparkplug coils with aluminum foil or plastic bags with rubber bands for starters. you should also cover the fuse box.
-if you use high pressure water, do not get too close, stand 4ft away depending on how much pressure you have going through the system. low/medium pressure is recommended.
some links with recommended products:
http://www.properautocare.com/howdoiclandd.html
http://www.autopia-carcare.com/inf-engine.html
Sweet! Thanks! I guess I probably coulda' Googled that tho', huh.. (whistle)
