endlink nuts question
You will need longer or adjustable endlinks when lowering. Awr if.you can find but you could go mcmaster too. Nothing special about endlinks.
As per the custom endlink thread; threaded.rod.works.great but if you can afford, turnbuckles better.
Anyway you slice it though, factory links won't work if your dropping more than an inch or so.
thanks for the input I'm looking into the ford escape front end links for the fronts after looking through old threads some more I'm unsure what to do for the backs my suspension is nothing major just tein s techs and I'm about to put on tokico blues? if anyone knows what end links are good for the back that are an alternative to awr? idk 110 bucks for some endlinks seems outrageous to me
