EMS to avoid dreaded winter fuel cut-off
arkitek
Greetings!
I'm looking for an EMS solution to mainly avoid the dreaded fuel cut-off when it gets cold here in the Canadian winter. Is there one?
I'm not a tuner so a chip & go solution is best.
Greatly appreciated for your help in giving me some info.
My mods:
CustomMSP SMIC
Custom 2.5 in turboback exhaust
Samco hose
NGK BKR7EIX sparkplugs
8-9 PSI ($5 spring)
I do remove the spring but it still hit the cut-off.
The SMIC & exhaust bring it up to 7psi and it's enough to hit the cut-off.
So a unichip does get rid of it then?
A DSM-AFC cured my car of fuel cut (which I was hitting at stock boost on cold days).
Like stated above, either Unichip, which is plug and play, or the DSM-AFC. Both have programmed maps in them you wont have to do alot of tuning.
