EMS solutions for the MSP
Black Majik MSP
Contributor
2003.5 Titanium Gray MSP #1699
I hardly know anything about EMS, but I thought I'd try to organize this EMS bickering into something constructive. I think the only way to properly choose a tuning option is to compare them independently of the car they are installed in.
*EDIT: All of the names are now links to where each can be purchased.*
AEM EMS
Base Price: $1875
Extras Needed: ??
Laptop Compatible: Yes
Tuner: Beau @ MAM
Controllable Functions: Everything :p
Pros: Offers a complete standalone setup & does it very well
Cons: Very complex & very expensive
Final Word: Doesn't seem necessary unless you're building a Protege race car or you're a "Super Tuner"
Haltech E6x
Base Price: $1400
Extras Needed: ??
Tuner: Juan @ HiBoost
Controllable Functions: Air/Fuel & Timing
Pros: Dependable
Cons: None
Final Word: Probably the best choice for Protege owners looking to make big #s & still be daily drivers.
Unichip
Base Price: $875
Extras Needed: ??
Laptop Compatible: No
Tuner: Unichip dealers/Corksport
Controllable Functions: Air/Fuel & Timing (manipulated)
Pros: good #s from current, limited tuning map
Cons: no user adjustability (must be sent to a Unichip dealer to reflash)
Final Word: Perfect for people looking for a "chip" upgrade that you can install & forget
MPI Tuner
Base Price: $750
Extras Needed: ??
Controllable Functions: Air/Fuel, Timing
Tuner: MPNick @ Modern Performance
Pros: Very widely used, tradeable maps
Cons: Steep learning curve
Final Word: Good choice for experienced tuner
GReddy Emanage
Base Price: $289
Extras Needed: Injector Harness ($37), Ignition Harness ($39), Software ($114)
Tuner: None
Pros: ??
Cons: Difficult to install & tweak, requires Profec E-01 ($509) for extra functions, no timing control
Final Word: Now that AFC is available, I don't see any point in buying this.
Airflow Logistics AFC
Base Price: $285 (GB)
Extras Needed: Boost Control (depends on method), FTC (significantly more $$)
Tuner: DSMConvert/Airflow Logistics/Split Second
Pros: On the fly tuning via R4 software...simply hook up the laptop and adjust/tune as needed. Maps can be traded electronically (windows files)
Cons: No timing control
Final Word: Great option for those looking for cheap tuning while still yielding decent #s.
I can add more to this as I get more info or if anyone has suggestions.
Eeek! You've got our totally wrong....
Extras Needed:
Pros: On the fly tuning via R4 software, simply hook up the laptop and adjust/tune as needed. maps can be traded electronically(windows files)
Cons: no timing control
Final Word:
MPI tuner should read like this:
MPI Tuner
Base Price: $750
Extras Needed: ??
Controllable Functions: Fuel, timing
Tuner: MPNick @ Modern Performance / User Programmeable
Pros: Most widely used, maps available
Cons: Steep Learning curve
Final Word:
Emanage can also do timing if you buy the timing harness. You'll also need an o2 signal modifier($100) regardless.
MPI Tuner
Base Price: $750
Extras Needed: ??
Final Word:
does upto four extra injetors, plus upto 12psi with only the stock injectors, does full timing control with boost retard has a built in O2 clamp.
The base system has made upto 240whp with stock injectors only. You should run extra injectors above 220whp.
Add this one too.. coming in about 2 months:
Microtech LT8S
Base Price: ~1400
Extras Needed: NONE
Laptop Compatible: Yes, Also handset controllable option
Tuner: User - Assistance from NSN Motorsports
Controllable Functions: Air/Fuel/timing/pump accel/auxillary
Pros: One of the easiest to use EMS's in existence. Full standalone capability. Feature Loaded
Cons: Re-Configuration requires sending back to Australia (~2 week turnaround)
Final Word: Coming in 2-3 months
Also can do auxillary injectors, 4 tuning modes, piggyback-able, 3-D mapping, auxillary inputs and outputs, can be user configurable to user requested numbers of load map points and timing points etc, full timing control, fuel control, water modification, air temp modification, cruise modification, WOT modification, timing modification at all previous mod points, reads 25 psi on internal MAP, upgradeable to 45 psi at purchase. Can drive independent coils, batch fire and sequential fire of injectors. And more...
I think Emanage needs to be corrected. You don't need the E01 to access the extra functions. In fact, you can access the most with a laptop. Also, you can control timing with 16x16 maps just like fuel delivery. It's much more powerful than a lot of people think.
Edit: You can trade maps with it, too.
Amen,totally wrong
Tuning software and a list of those who have the EMS would be a good addition. If you list those who have it (or are willing to be listed) it will give people the option to get help from each other.
AEM EMS
Base Price: $1875
Extras Needed: ??
Tuner: Beau @ MAM
Haltech E6x
Base Price: $1400
Extras Needed: ??
Pros: Dependable
Cons: None
I totaly dis agree with the haltech vs aem.... aem is very user friendly and easier to tune then haltech.... no one wil give maps with the haltech because it is almost impossible to tune unless you've had experence. ive tried to get my friends civic to run on the haltech and we couldnt get it to idol. now he uses a Vortech fmu and a SAFC and puts 624 down on a b16. we gave up on haltech, aem is going in the protege and the civic soon.
CWiLL said:
AEM EMS
Base Price: $1875
Extras Needed: ??
Tuner: Beau @ MAM
Haltech E6x
Base Price: $1400
Extras Needed: ??
Pros: Dependable
Cons: None
This thread is not for discussion or argument of EMS systems, rather as information only.
GReddy Emanage
Base Price: $289
Tuner: None
Pros: ??
THIS STATEMENT IS TOTALY WRONG!
The e-manage IS laptop compatable and it DOES control timing. To use this
Piggy-back you should also buy a FM volatge clamp($100) and the Greddy
Pressure sensor(3 BAR MAP, $100). To anyone that is considering using the
E-manage, the unit is user friendly and their are alot of tuners that know
how to use it and i beleive it is the most afforable for use in tuning
Fuel/Timing.
i understand but the pros and cons were wrote by who? the ppl who design the systems? or by the person who started the thread? if u want the facts then u should post fact not opinions
I agree with that.
Sorry, I've been busy lately...I'm going to fix everything & add a section to each that lists what it's manufacturer says it can do. I'm going to eliminate the Pros/Cons & basically combine the opinions into a Comment section.
never tuned an AEM but my haltech was an absolute breeze to tune on the protege. as for no one giving maps....there are a few of us here who would be happy to give anyone a basemap for either the e6 or f10 unit
